Good day!!! The D.W. would like me to hook up an H.D. antenna to our house using a travel trailer antenna. is this is possible, or will this work? I am trying not to run a cable from the existing...
The Jack antenna is highly rated. I use one and it works better than expected. as has been mentioned, they come with a pole mount bracket, amplifier and cable. has everything you need to get you set up.
