Good day!!! The D.W. would like me to hook up an H.D. antenna to our house using a travel trailer antenna. is this is possible, or will this work? I am trying not to run a cable from the existing...
There's nothing special about a RV antenna, except it's on a crank to lower it.
Channelmaster & Wineguard make good home antennas.
ANTENNAWEB.ORG is a good guide to selecting an antenna that will get you good reception at your house. You may also need an amplifier, depending on where you are in relation to TV stations, and on the terrain.
