Halmfamily
Jun 06, 2018Explorer
RCMAN46 wrote:
To the OP
When you first pumped the fuel filter did you open the bleed screw until you got diesel fuel.
Then after diesel fuel at bleed screw close the screw and pump until it becomes very hard.
I suspect and agree you need to overhaul the filter head. Very common problem with the Duramax especially if it has a lot of miles on it. Merchant Auto also has a spacer for the filter head which makes changing the filter a little easier.
I did as you said but would not start when I tried. Once I rolled it back level that's when my son started the truck. It sat level for several minutes before he started it. I did ask him if he did anything different and he stated he left the ignition in the on position for about a minute and it started.
