ScottandCathyExplorerMay 01, 2015Had to replace the TIPM in my 2006 Dodge RamWent to use the A/C about a month ago and it was not getting cold at all. The compressor clutch was not engaging. Checked the obvious, ie., broken or loose wires/connectors. Had power at the switch i...Show More
Grey_WolfExplorerMay 02, 2015If you have a TIPM I would suggest a fuse box between the seven pin and the TIPM!
Related ContentDodge - TIPM & Modulite ?Replacement Lights for TTReplace insulation inside heater column.Water Heater Replacement Recommendations6.4 Dodge???
