FLGup's avatar
FLGup
Hail....how hard to replace skylight
We had a hail storm this evening and the skylight over the tub was busted thru. The inner-shell didn't break, just the rooftop outer-shell. I tapped it over with duck tape and covered it with a trash bag, tapped down to keep the rain out tonight. Sigh.. Bad timing as we are leaving Saturday for our big trip.
Anyway I'm not sure the dealer will be able to get to it as fast as I would want, a lot of damage in the area so I'm sure this is small potatoes.
The question..... If I can get a outer shell skylight from them, how hard is it to replace? How do you get the sealant off and prep the area for a new skylight? What Dicor is best for installing a new skylight...self level or non leveling?
  • I saw your post on the Keystone forum. Use a heat gun (to warm and soften caulk) and plastic scraper with utility knife to remove old caulk and skylight. Hopefully the screws will back out with a screw gun. Be careful with heat gun and utility knife to not slice or overheat the roof membrane.
    Do a YouTube search for rv skylight replacement or installation and I'm sure you will find good step by step instructions.
