Although you don’t provide any mention or detail about your F150….could be a clapped out ‘99 single cab short box 6 banger 1 wheeler peeler with a 5 speed manual, or could be a newer crew cab high zoot with over 400hp, 10 speed and like 6 tons of towing capacity rating….I’ll assume for the sake of argument that it’s a relatively well equipped newer “big” F150 with roughly double the towing capacity needed for your 6klb tops fully loaded trailer.
If there are no restrictions on the roads you mention that would prohibit a combined length of vehicle shorter than your combo, then it’s simply your experience or reservations about towing that is in question.
Apparently you’ve done the math and both routes are scary to you.
No need to stress out your trip and piss off the line of vehicles behind you as you white knuckle it up and down those roads, not seeing the sites because you’re hyper focused on not dying.
Not all highways are ADA (Asian or Apprehensive Driver Approved) lol.
Sounds like these roads fit the category for you.
Have a less stressful vacation and dump the camper down low. No need to try out for the Olympics if you haven’t even started working out yet.
Or in other words, just because you can, don’t mean you should.
Hope this helps!
