Thanks! I know I was a little short on info. It's actually not the mountain driving I'm concerned about, it's whether the truck is up for the grades. It is a 2020 F-150 with the 2.7L Ecoboost and towing package which tops out at about 9,000 lbs capacity. I haven't weighed the trailer but your guess matches mine, probably about 6,000 lbs fully loaded. We went up an 8% grade recently and it felt like that would be its limit. The transmission temp was 210 (I'm not sure how much that matters but it's the hottest it's been since I've been watching). That was a relatively short grade, maybe 3-5 miles. I don't know how it would handle a long uphill slog because this is only our second season and haven't encountered anything like Yosemite.
I've been trying to find someone who's actually been up these roads because the guidance on the website is ambiguous. For example, on the CA-140 (Big Arch entrance) it mentions a 45' vehicle length restriction but offers a 60' combined vehicle restriction (max 35' trailer). The CA-120 entrance mentions the 45' limit but not the combined vehicle. I'm not sure if that's a fact or a website oversight. Also, I've read to take the CA-140 entrance because it's flatter and < 3000' elevation but once you're in the valley if you need to go to a campground at 7,600' then I'm not sure if it makes much difference taking CA-140.
Quiet day, so I got a bit wordy:
GVWR of the trailer is 6000lb...If the truck has a 9000lb tow rating, you are well within the motor's capability.
- transmission should have no problem. It's mated to more powerful engines.
- The engine can put out the power, just watch the engine temps. On flat ground, you are likely running little if any turbo boost. If you keep the hammer down on a long grade, you are likely running a lot of boost the entire time and burning a lot of fuel. That creates a lot of heat in a small engine block. Probably won't be a problem as you aren't pushing the truck to it's limits. If you can feather the throttle or run in a lower gear, so it isn't running a lot of boost, that's good. Worst case if it starts getting hot, find a place to pull off and let her idle for a few minutes until temps come back down. Don't worry too much about speed, these are routes geared toward tourists watching the scenery.
A good way to check grades is download google earth (different from google maps) onto your laptop. Enter your route and then right click on the route. It will give you the option to show elevation profile. We've found it pretty accurate for determining how long and how steep the grades are.
For fun, I pulled up the routes to look:
- Hodgodon Meadows: Out of Coulterville, you have a 3 mile 7% grade. Then a bunch of short up and downs. Then two separate 3 mile 6.0-6.5% grades. (ending elevation ~5000ft)
- Mariposa to Bridal Veil: Starts with a 3 mile 6% grade, followed by a downhill 3 miles at about 7%. Probably the worst of it as it's on a twisty section but nothing crazy. Then a long modest grade mostly around 1% ending with a 9 mile climb ranging from 4-6%. (ending elevation ~4000ft)
Use the tow/haul and/or force it into a lower gear starting downhills. Start the downhills a bit slower than you would be comfortable with. If the speed starts getting a bit high for comfort, firm braking until you are slowed down and then release the brakes. Don't ride the brakes as this can cause them to overheat. By releasing them, the brakes have a chance to cool down.
All that said, you should be fine in terms of grades (I didn't check any length restrictions and it's been a few years since we were there).
