My bad. I thought it was driving apprehension not equipment concerns.
I’ll check but I’m almost certain those 10 speeds run around 200deg normal operating temp. My last 2 Chevy 10 speeds did (same trans). I’ll check the F150 I’m driving now.
Keep the gears low, rpm’s up especially if the trans is building heat. And good trailer brakes. Wouldn’t bother me to pull that trailer with that truck up a mountain.
If I showed you pics of 10klbs on a 4klb trailer behind a half ton Silverado with the factory weenie rear tires pumped up to 65 psi over Chinook, Cayuse, White, Snoqualmie, Blewett, or Stevens passes or pulling the grade out of Vantage either direction from the Columbia. Sometimes on hot summer days, you would have no worries about your trailer in Yosemite.
Let er buck!
Haha! Great, that makes me feel better about it. I kick myself for not getting a bigger truck but it is what it is. Since I have the towing package I've got a few positives in my corner. In towing mode it does keep the gear low automatically going up, downshifts automatically going down, and has a way to tweak the trailer braking.
- Grit_dogMay 14, 2025Trailblazer
Eh, I mean unless you got a 3/4 or 1 ton you’re not missing out on much.
As you know, the size and suspension on the F150 is solid for a trailer your size.
And it’s got enough gears to make that little Ecoboost put out. Especially if you have deeper final drive ratio.
You’ve got the torque comparable to an average of the “big” gas motors offered in current half tons.
And the bonus is you make all the torque by 2500rpms ish and it’s relatively flat.
What kinda combined city/highway driving mpgs you get?Im pretty blown away by the ole 5.0 in my work truck. Getting a combined 18mpg commuting. Either stop n go or driving it like a rental!
- apjinorMay 14, 2025Explorer II
Yeah, I was thinking I should have got an F-250 but we ended up getting a trailer to suit the truck rather than a truck to suit the trailer. I'm glad to hear it's not so far off but that's the thing about the gas mileage - it's no better than your 5.0! What I usually say is that I get 18mpg in the city, on the highway uphill, downhill, in the wind and going straight. Never seems to change (except for steep grades). I can even pull our trailer on flat roads and it gets 17 but with hills it goes down to 9-10 pretty quickly. In the truck envy department, a campsite neighbor last year had a real nice GMC HD with all the bells and whistles, he said he got 22-24 on the highway...! First thing I did was go home and calculate how long it would take for us to break even (back when gas was approaching $5/gallon) to upgrade to that truck. At that price for gas, it wouldn't be long. Wife wasn't sure I was serious but the numbers don't lie!
- valhalla360May 14, 2025Navigator
If you are getting 17mpg towing a 6k trailer, never sell that truck. 9-10 on flat ground would be more what you should expect towing, so that's spectacular.
Keep in mind, it wasn't that long ago, a big V8 engine might put out 250hp. That little 2.7l has something like 325hp. Again, the only thing to keep an eye on is engine temp.
