bmcewan
Aug 14, 2014Explorer
Half ton TV advice
I'm new to the TT world, looking for a 19-26' TT for the wife and I. We planning to semi-retire in 5 years, when we'll be late 40's, and live a minimalist lifestyle, try fulltiming and visit a lot of the national parks.
I've read a lot of threads on the viability of pulling with a half ton pickup, and what it seems to come down to on these trucks is a low payload weight. Since there is a lot of variability in half tons, here's what I have. A 2011 Ram 1500 Tradesman, with tow package, which gives me some nice-to-haves. My limiting factor appears to be payload. Here's my TV specs:
Class IV receiver hitch, 4 and 7 point harness.
V-8 Hemi, 390hp, 407lb-ft torque
Heavy duty oil cooler
Heavy duty transmission cooler
160 amp alternator
3.55 gear ratio
Multilink Rear coil springs
6350 GVW; 14000 GCW; 1440 max payload
Max trailer 8900lbs.
To improve towing capacity, will add:
* load balancing system
* integrated electronic trailer brake controller
* 1000# rear suspension airlift system
My problem is, between the wife and I and a full tank of 26g of fuel, plus 50# of extra gear, and subtracting the 150# of driver weight (boy I wish I was back at 150#!) we're left with payload of 870 pounds.
Dialing in the tongue weight at 15% of trailer weight, I'm looking at a limit of 5800 pounds.
Have I calculated this correctly? Any advice for fulltiming in something this light? I suspect the answer is "give up and buy a 3/4 ton truck." But would appreciate any help analyzing this and some advice on looking at the problem from people with more experience on this than I. Thanks!
160 amp alternator
3.55 gear ratio
