bmcewan's avatar
bmcewan
Half ton TV advice
I'm new to the TT world, looking for a 19-26' TT for the wife and I. We planning to semi-retire in 5 years, when we'll be late 40's, and live a minimalist lifestyle, try fulltiming and visit a lot of the national parks.
I've read a lot of threads on the viability of pulling with a half ton pickup, and what it seems to come down to on these trucks is a low payload weight. Since there is a lot of variability in half tons, here's what I have. A 2011 Ram 1500 Tradesman, with tow package, which gives me some nice-to-haves. My limiting factor appears to be payload. Here's my TV specs:
Class IV receiver hitch, 4 and 7 point harness.
V-8 Hemi, 390hp, 407lb-ft torque
Heavy duty oil cooler
Heavy duty transmission cooler
160 amp alternator
3.55 gear ratio
Multilink Rear coil springs
6350 GVW; 14000 GCW; 1440 max payload
Max trailer 8900lbs.
To improve towing capacity, will add:
* load balancing system
* integrated electronic trailer brake controller
* 1000# rear suspension airlift system
My problem is, between the wife and I and a full tank of 26g of fuel, plus 50# of extra gear, and subtracting the 150# of driver weight (boy I wish I was back at 150#!) we're left with payload of 870 pounds.
Dialing in the tongue weight at 15% of trailer weight, I'm looking at a limit of 5800 pounds.
Have I calculated this correctly? Any advice for fulltiming in something this light? I suspect the answer is "give up and buy a 3/4 ton truck." But would appreciate any help analyzing this and some advice on looking at the problem from people with more experience on this than I. Thanks!
  • a 23 foot Ascend A231RBK with dry weight under 4,000 lbs. would easily work if it is adequate for your needs.
    bumpy
  • Don't forget the WD hitch will add around 100 pounds to the tongue as well.
    I would think a trailer somewhere in the 7000 pound wet, fully packed for your trip is going to be all you will want. Others will say you can go over on the rear axle load and you probably can for awhile but it will be more stressfull and stopping a heavier load could be difficult.
  • If its only you and the wife I would look at the nash 4 season with off road chassis.
    This is the floor plan I have. Having opposing couch and dinette is the best set up with rear bath.
    tongue probably around 650lbs but with WD will bring it down some..
    This IMO is one of the the best options for what you want to do..
    nash 24m.............
    Otherwise get a class A and sell the truck. Pull a jeep or something behind the class A..
  • Hello... Take the truck to a scale and get the truck weighed. Make sure you get individual axle weights..
    Then come back and post those #'s
    And post the axle ratings on your door tag..
    This will give you a better idea of what you can tow..
  • The payload would limit the selection on fifth wheels....A TT's tongue weight is not as high..
