CraigGe's avatar
CraigGe
Half-ton TV options
I've done quite a bit of searching, but every situation is unique, so I figured I would solicit some input for my own scenario. Appreciate any advice you all can provide.
After having rented RV's for several years, I've decided it's time to buy a TT. After finding out that the TT I really wanted was too heavy in the tongue, I believe I've found a couple of alternatives. The question is… can my half-ton handle it? To get right to it, here are the numbers:
2013 GMC Sierra 1500 5.3L V8, 3.42, tow kit
Truck:
Curb: 5,487 lbs
Payload: 1,513 lbs
GVWR: 7,000 lbs
Max Trailer: 9300 lbs
GCWR: 15,000 lbs
Axle ratings: 3,950 lbs
Hitch:
Max load with WDH: 1100
Est. Additional Truck Cargo (including people):
800-1,000 lbs
Trailer 1:
Dry: 5,727 lbs
GVWR: 6,900 lbs
Tongue weight: 544 lbs
Trailer 2:
Dry: 6,550 lbs
GVWR: 8,600 lbs
Tongue weight: 560 lbs
Tire max load: 2,469 lbs
On the surface, everything appears to check out. What do you think about the 2 trailer options?
  • Works for me. Either one. Of course if you had a Ford there would be no question.
