atlgagent57's avatar
atlgagent57
Halt Ton Towing
We recently purchased a 2011 Toyota Tundra CrewMax Platinum Edition with the 5.7 Engine, Towing Package, 20 inch wheels and it has the 5.6 Bed. The Tundra is rated to tow 10,000 lb. I'm having the tires replaced with E Rated (10 ply) tires and I'm having rear Timbrens installed over the leaf springs It has also been fitted with an automatic slide 5th wheel hitch for pulling a 5th wheel. We also purchased a 2008 Keystone Laredo 5th Wheel with a 7740 Dry Weight and a 1440 Hitch Weight according to the manufacturers labels. It's a 30 footer with one slide. There are just the two of us and two lap dogs so we won't be loading the camper to the max. Bikes go on the rear of the 5th wheel which should help the pin weight. I've pulled it a couple of times on the Interstate and it pulls fine. A lot of it is using common sense when towing regarding speed and allowing plenty of space to stop. Exceeding the speed limits and riding the guy in front's rear bumper is simply inviting trouble no matter what your towing vehicle is. I've also seen plenty of 3/4's and 1 Tons out there towing a TT that is not set up correctly that are far more dangerous than my half ton rig. I've matched the two up the best I can, added some safety features and will use common sense when we're out there.
  • I am really not an expert on 5th wheels but that 10,000 lb tow rating is not having a 5th wheel hitch in the bed of the truck and the 1600 lbs it will have hooked to it. Loaded weight and actual weight are two different things. Stopping and down hill are another thing altogether. Wishing you luck.
  • The thing that you need to remember is what YOUR rig is designed to tow.
    Do not rely on dry weight because it can be deceptive. Particularly if you are at or close to your max. weight. The weight you need to be concerned about is the GCVWR (Gross Combined Vehicle Weight Rating) of your TV. If you are within 80% of that max., you are approaching problems.
    You will read lots of posts on this forum about how well their rig tows when overloaded. Don't be swayed. Their rig will wear out faster, break down sooner and become unpleasurable to drive sooner than if you have an adequate tow vehicle.
    It sounds like you are trying to justify towing with an inadequate rig by citing all of the "extras" and safety things you do. Here is the issue: If you are overloaded or close to your max., and you have a panic stop (an unanticipated emergency 'slam on the brakes' stop), you more than likely will find brake fade or failure. You can't plan for that type of stop. You can plan for minimizing the effects by towing within the rating on the tow vehicle.
    Not only that, but you will spend a lot less money in the long run if you start out with an adequate tow vehicle.
    I expect to be trashed for saying this, but I have been there-done that with an inadequate TV. When I upgraded to a vehicle designed to tow more than what I was, I never had trouble or expensive repairs.
  • Sounds like you've thought it all through. The only thing I'd add is that you visit the scale and verify all the applicable weights to make sure your calculations and assumptions are correct.
