The limitation of Ham, CB, FRS, GMRS is that the hand held units have their output limited to avoid damage to the user's brain. Need a mobile unit connected to the vehicle's 12v DC for power and an external antenna to get much range. Even then it is line of sight so OK for wide open spaces but not for wooded, rocky, or hilly areas.
With a cell phone the tower is well above the horizon and it is putting out a much stronger signal then even a Ham transmitter station. In the USA the best geographic coverage is with Verizon.
VHF is not legal for use on land unless you are a marine business operator. It has the same power limitations of Ham and GMRS. FRS is so limited in terms of range as to be nearly useless most of the time. Unlike a cell phone conversation where only a couple million NSA employees and contractors can listen in, with FRS/GMRS/Ham/VHF anyone can listen in with ease.
