FireGuard
Mar 04, 2019Explorer II
Handling comparison: SRW vs DRW at GVW
I don’t think anyone would argue that a DRW is more stable at carrying a TC but let’s hear some thoughts when comparing “apples to apples”
For example let’s assume trucks are both new Ram 3500 4x4 diesels.
1) Ram SRW SB with a payload off approx 3800 lbs carrying a Lance 855 S which is 8’11” with a slide and a wet weight of 3800-4000 lbs. and approx 2’ of overhang.
2) Ram LB DRW with a payload of approx 5000 lbs carrying a Lance 1172. 11’11” and wet weight of at least 5000-5500 lbs. and almost 4’ of overhang.
Both trucks will be at or slightly over GVW rating but assume within axle and tire limits.
I’m sure if you wanted to get scientific and calculate wheeelbase, cog, weight, overhang, roll moments etc you would get a scientific answer, but what do you think seat of the pants feel would be?
Would a SB truck at its GVW be as stable as a DRW at its GVW?
To add more thought, add a few hundred lbs of hitch weight for towing.
