RamTC
Nov 29, 2014Explorer
HappiJac 4150 Problem
So much for "HappiJac's Acme Screw Jack is the first acme screw jack with a redundant safety check system"
One of my rear jacks failed, has no ability to raise/lower or hold up the camper, just slips. I'm glad it only takes one rear jack to hold up the camper or the TC would have went over. Switched to manual, no help as jack just makes a bump noise and slips with any weight on it. Took the motor off, all looks good.
Anyone else experience this type of dangerous failure, what is the mechanism that is supposed to prevent the jack from collapsing under load ?????. Looks like I'm just going to replace with a new 4150.
I assume this 'cube' swagged in top of inner (black) tube as in Kkellers14k pic. Hopefully Happijac works with you on this
