BradW wrote:
https://www.youtube.com/watch?v=Vy6gKROASGQ
Can you loosen the bolts make some adjustment and then retighten them? There will be some slop in those bolts holes that may give just enough movement to get things lined up. If not, maybe a few strokes with a rat-tail file will get you what you need.
Bradw
The bolts have square shoulders, so they force-center into the holes - that's how they keep the faces from rotating. No adjustment is possible. I was thinking of grinding off the shoulders on the swing out bolts and opening up the holes in the brackets to get more play. To prevent rotation, I could dowel the swing out and the brackets using 0.250" pins.
I really want to avoid having to shim the Z-bracket, because that might require new holes next to the old ones in the corner of the camper.
