anaro
Aug 26, 2013Explorer
Have you looked at these?
Palomino solaire ultralight. It lists as 23'4" and is really light. The Dakota might be able to handle it. I don't think you'll be putting 3000 lbs gear in it. It will probably be closer to 5000-5500 lbs loaded. Which means a tongue weight of around 650-825 lbs. So if that is within specs for your Dakota you could try. I suspect you will ant a larger vehicle sooner than later though.
Here is a lighter and smaller tt by forest river. Forest river micro lite
