I'm beginning to think that the weigh station that we use is off a bit. The camper's outside weight label says 2,160 dry without options and 2,456 wet. The inside label says 2,630 which I thought was the weight as it leaves the factory - with options but without batteries or filled propane (since they don't know what type of batteries the dealer will install). So based on your weights and the 10,060 number in your original post, my setup should not be any more than yours since our truck is lighter (and we don't overpack). I guess it doesn't matter a whole lot though since the truck certainly handles the camper well. Just like the idea of being pretty close to GVWR.
