wintersun
Oct 04, 2014Explorer II
GeoBoy wrote:
Torklifts all the way, they are true frame mounts. Your 2500+ lb. camper mounted to the frame is much better than the sheetmetal of the box and the metal of the rear bumper!
Regardless of the tie-down the turnbuckles should not be tightened to provide more than 300 lbs. of tension or the brackets mounted in the camper will pull out. Fastguns are designed to make it easy to know that you have them set for 300 lbs. of tension at each mount.
44,066 PostsLatest Activity: Mar 14, 2015
