Anonymous
Jun 11, 2015Not applicable
Had the infamous filling problem over the years. If your water pressure filling the fresh tank thru the gravity till is too strong, you risk having water back up into the overflow tube. When this happens the air being displaced in the tank does not escape efficiently which can result in water coming out the gravity fill hole.
When I get this, I use my air compressor and blow out both the tank fill hole and the overflow tube. Then I restart the tank filling at a reduced pressure. This has worked every time for me.
