bedpan
Jun 10, 2015Explorer
Hard to Fill Fresh Water with Gravity Fill
Just picked up our new 2015 Starcraft 18BH. Had our first weekend in it and all went well. Some learning to be done but overall no major issues.
I sanitized and the fresh water system prior to leaving as per the manual and online guides (drain, bleach water, soak, drain, rinse..). During the fill cycles I find it pretty tough to fill using fresh water tank using the gravity fill. Although the manual says there is an options to fill via the pump I don't think it applies to my trailer as there is no water line that connects out of the pump back to the tank.
So filling via the gravity feed appears to be my only option. Using a hose (drinking quality of course) holding it in the gravity feed hole about 50% of the water comes pouring back out. I bought one the fill adapter for the hose with the shut off, and soft plastic tip. Even with that water still pours back out. Getting just the right angle and flow rate I can keep most of the water going in. This is not a big deal if I am running off a city water hose, it was a real challenge to pour the bleach water in without spilling all over. The larger issue will be if I am trying to put in bottled water of some sort.
Any thoughts or suggestions? I can post some pictures if required? I was wondering if I should cut in a by pass so I can fill using the city water tank? Any risks in doing so?
Thoughts, answer, solutions all appreciated!
I am new so be gentle ;-)
thanks,
Mike
thanks,
Mike
