- jerem0621Explorer II
RWDIII wrote:
just weighed my new 2015 F250,within 20lbs
Nice truck! - RWDIIIExplorerjust weighed my new 2015 F250,within 20lbs
:) - Buck50HDExplorerBoth my F150HD and current F250 were right on. I didn't actually weigh them at "curb" but by subtracting the few things inside it (me, 5th hitch and tonneau cover) the curb weight suggested by the sticker was accurate. Both were done with a full tank of gas.
We had truck scales at home growing up and if you sell anything they have to be certified. The NIST says within 1/2 of the unit on the scales. Ours had 10 lb marks so it had to be within 5 lb.
I've got a scale my Grandpa had in his nursery to weigh grass seed that was probably last used in the late 70's and it's max weight is 5 lbs and he had to have it certified by the state of CA Weights and Standards.. I've got it on display in my house and it has many stickers placed over top of the other on it... I remember that scale being in the nursery for as long as I can remember (he opened the nursery in the mid 50's) :)
I think the CAT scales only weight in 20lb increments, so I guess that's as close as they need to be??
Anyway, I never did weigh my new truck "empty", but I weighed it once on a closed DOT hwy scale that they weigh commercial vehicles on and even loaded for bear with my TT all hitched up and all the junk I haul, I was still #600 under the GVWR of the truck...
Yes, I would still like to get an actual "empty" weight of the truck, but my registered "scale weight" is #5416.. But my payload sticker says #1920 from a GVWR of #7700. So that comes in at #5780..
So that's #364 difference and I'll bet that's the difference between a plain jane "XL" and my "XLT" with MAX TOW??
I just wish I had more than a #4050 rear axle weight rating... ;) As I was only #400 from that when I got that actual weight on that DOT hwy scale.. :(
Mitch- goducks10ExplorerI've weighed mine and it was pretty close, but I use the RAWR anyway so I'm not too concerned.
- RaftenExplorerEvery time I load my TC.
- lbrjetExplorerI stopped at the CAT scale on the way home after picking up my new truck 5 years ago. The payload sticker of 2660 way spot on.
- blt2skiModerator
brulaz wrote:
Have weighed my truck several times, and as best I can tell after accounting for what's been added to the truck since factory, the payload sticker is correct.
IIRC, that 150# driver BenK is referring to is used in tow capacity and GCWR(?). But not payload (or curb weight or GVWR).
Correct, along with the camper load will be the total payload less # of seatbelts times 150 lbs to get the camper load. So for my 2000 C2500, 3700 less 450 lbs or 3250 lbs of camper.
Marty - brulazExplorerHave weighed my truck several times, and as best I can tell after accounting for what's been added to the truck since factory, the payload sticker is correct.
IIRC, that 150# driver BenK is referring to is used in tow capacity and GCWR(?). But not payload (or curb weight or GVWR). - kaydeejayExplorer
BenK wrote:
Gonna disagree with you Ben! Until I retired from GM that was one of the labels I was responsible for.
I say it is based on the curb and no options with one 150lb driver.
Effective 2005 model year "The combined weight of occupants and Cargo should not exceed XXXX" (aka "Payload") number was calculated for EACH vehicle "as built", but empty, and was supposed to be accurate within 10#.
