joerg68
Jun 15, 2019Nomad III
What do you seek to improve? The current water heater is there and works just fine as-is, right? At no extra cost.
Instantaneous heaters usually need a short time to reach the desired output heat - some extra water is probably wasted that way.
Usually, fresh water is a more limited resource when traveling than LPG.
You would also reduce your fresh water reserve by the 6 gal. in the boiler tank.
In winterizing it might save a few minutes.
44,066 PostsLatest Activity: Apr 15, 2026
