paulfredricks's avatar
Mar 27, 2016
Hatch Trim
The trim around the hatches on our 2004 Travelstar hybrid are looking pretty bad, and I haven't been able to get them clean. The thought is to replace the stripping, but I can't seem to find what I need. I hope it's still available.
Here is a picture of one of the hatches, and a side look at the trim. Any ideas where I can find it, or how I can make it look like new again?
  • I thought that looked odd.
    Mine definitely has the screws UNDER the screw cover.
  • Since I now know that it's called screw cover, I assume that it shouldn't have any screws showing which mine does. So I've decided to replace it. Should make a big difference in the look. Thanks all!
  • I have similar stuff around our door and when I couldn't find it at the local rv shop I tried a mr clean magic eraser. Cleaned it up like new.
  • Screw cover! Those are the magic words I was looking for. Google it and there it is! Thank you!
    http://www.amazon.com/Narrow-Marine-Camper-Insert-Cover-Polar/dp/B008I62UE2/ref=sr_1_4?ie=UTF8&qid=1459214325&sr=8-4&keywords=rv+screw+cover
  • drenjoey wrote:
    When I had my Travelstar, I used Clorox bleach in spray. Sprayed it on and waited.....then wiped it down ! Another product I use was called Awesome (Family dollar) ....did a good job too !
    It's called screw cover. Take a sample to your dealer because there's several different sizes. He should have it in stock.
  • I'll try those ideas. I'm in CT too (Bethel) so I'm not too far away. I'll try the bleach spray first.
    Thanks!
  • When I had my Travelstar, I used Clorox bleach in spray. Sprayed it on and waited.....then wiped it down ! Another product I use was called Awesome (Family dollar) ....did a good job too !
