Carrying water is unnecessary in most cases. For me we bring bottled water for drinking and only a minimum in the tank for flushing. Very minimum.Unless boondocking there is no need to carry extra unused weight. Most TT are sized with minimum carrying capacity, so why use it up in carrying something you wont need to use unless you are boondocking for extended time. depends on your vehicle gross weight capacity but most 21 footers use 3500 lb axles and the trailer is usually around 31- 3200 lbs dry, so that does not give you much room before you max out the axle. So if you have single axle keep in mind the GVWR when filling up.
