CAJWExplorerMar 18, 2015Have a Dually with an valve stem mounted TPMS?If you have a dual rear wheel truck with an aftermarket, valve stem mounted, TPMS (tire pressure monitor system) sensor, you probably already know that the batteries need changing periodically. As lu...Show More
dbblsExplorerMar 18, 2015I don't use the set screws to lock mine on. I have not lost one in over two year.
Related ContentDually valve extensions?Dually valve stem extenders; which one?Borg Dually Valve Kitford dually valve stem issuesWhich dually valve stem extender?
