2012Coleman's avatar
2012Coleman
Explorer II
May 31, 2017
Having 30 amp plug installed at home
My previous home had a 30 amp plug which was very nice, so I'm spending the money to have an electrician I have used on several projects install one. Since my existing panel does not have room, one will be added. He will be pulling a permit.
Can someone tell me in simple layman's terms what voltage/amps are needed on each prong so I can question him on what his plans are? I've read other posts where someone's electrician did the wrong thing with bad results. He has seen the plug, and he's not a novice.
I know virtually nothing about this topic, so I'd appreciate the "For Dummies" version.
Thanks in advance.
  • I wired in one at our cabin. Really simple. Plug in a 30 amp breaker into your panel. If it is full you will have to wire in a sub panel.
    Run a 10 gage wire to the the 30 amp outlet. Pretty hard to go wrong.
  • It's 120 volt Not 240 volts.
    It's an RV outlet Not for a washer/dryer.
    Might consider a 50 amp 240 volt for the future.
  • First and foremost, it is NOT, and I repeat NOT a 220-volt circuit like a clothes dryer or range. It is a 110v circuit and is normally wired with a 30A breaker and 10-gauge wire.
