transamz9 wrote:
The fact of the matter is that if you mash any of the HD trucks to wide open throttle then you will be the fastest one off the line unless someone is racing you.
Good point but torque management muddies the waters. The higher HP truck should be faster. Problem with these trucks with massive torque though is you can't use it off the line without tearing up the tires or breaking parts. Even with traction control, there is only so much power you can put to the ground
An Audi Q5 TDI with 240 HP 420 lb ft is faster 0-30 than an SQ5 with 354 HP 347 lb ft. same transmission. After that, the SQ5 is long gone.
