FishOnOne wrote:
Yep my truck runs very strong and makes very good fuel economy without a after market tuner. But perhaps you'll run into those "high up Chrysler guys" and just remove your tuner to be on the safe side when taking your truck in for a repair. :B
Troy try to keep up buddy :W
I never said anything about "high up Chrysler guys" and I do not have a tuner on my truck. I took my truck up to Green Diesel Engineering you know the guys that write the ECM and DTECM programs for GM, Ford, VM the maker of my engine, along with others. The rewrote the factory program to remove the BS that the EPA makes ALL manufactures add in even your great all mighty Ford.
I still have the same ECM the truck was built with, my dealer is on board with this and there is no way this can be found. My truck was making great mileage before the rewrite and even better now. Along with cutting out the EGR and regens to a bear min. But hay spin it anyway you need there buddy :W:W
Don
Ron this was intended for Troy not you. Just didn't get all of your post cut out.
