Desert_Captain
Sep 19, 2019Explorer III
"I don't know how anyone could tell that I was not using tow/haul by what I wrote."
No offense intended but this is what you wrote, sounded like you weren't using Tow Haul:
"On the downhill runs however, the engine is still a 3.5 liter gasser when it comes to motor braking. I have to use my brakes more than I would like on the long high speed drops. Today I came down what is probably my steepest, curviest downhill in my driving experience. This road was handled well by the EB because the speed limit was 25 and I could use first gear and had very good speed control with engine braking."
If you are in TH you should not have to use your brakes much at all. A light tap of the brake pedal will downshift the trans one gear, no need to manually shift down unless that's what you like to do though it does seem a tad redundant.
On a long 5 or 6 percent grade I select a speed that is appropriate for the road conditions and set cruise control while in Tow Haul. This usually gets me to the bottom of the grade without ever touching the brakes or at most doing so lightly and not often.
As always... Opinions and YMMV.
:C
:C
