BarabooBob's avatar
BarabooBob
Explorer III
Sep 17, 2019
Heading to the Rockies for 5 or 6 weeks.
Well we have been traveling all over the place and I found out how my 3.5 EcoBoost would handle the Rockies. Going up hills I have no problem with power at all. I slow for the corners and speed back up to whatever speed I feel is safe. We have passed many gas Class A's that are in the slow lane with their engines screaming to get to the top.
On the downhill runs however, the engine is still a 3.5 liter gasser when it comes to motor braking. I have to use my brakes more than I would like on the long high speed drops. Today I came down what is probably my steepest, curviest downhill in my driving experience. This road was handled well by the EB because the speed limit was 25 and I could use first gear and had very good speed control with engine braking. I only had to touch the brakes a few times on that stretch. This was in Colorado between the towns of Dinosaur and Fruita. I don't remember the road number right now.
For an everyday driver with only limited towing in the mountains, I really like my EB and may buy another one in the future. I will have to do some serious thinking before I get a new truck because I may buy a diesel with exhaust brake. I don't know what size truck at this time. They keep changing options on trucks so time will tell.
  • New trucks have tons of power and are a joy to pull with compared to when I started driving. Power will definitely not be an issue with any newer truck, as they will pull way more than they can safely control.
  • It sounds like you are not using your Tow Haul so I would have to ask why? Any time you are towing or loaded heavy as in "hauling" the Tow Haul should be engaged. With TH on going down long steep grades, 5 or 6 percent, you will hardly use your brakes at all. Even better you won't be burning a drop of gas all the way to the bottom and will arrive with nice cool brakes ready to perform.
    When climbing even a slight grade of 2 - 3 percent you are slowly but surely cooking your transmission by running with TH off. Once in a great while I forget to turn it on and my Scan Gauge quickly reminds me to do so as the trans fluid temperature quickly climbs 12 - 15 degrees... engage TH and I watch it drop by that much in just a mile or two {this on our 2011 V-10 in a 24' Class C}.
    There is simply no good reason not to use Tow Haul.
    :C
  • I believe the road you are referring to is route 139. We drove that road several years back in our class C on the way to Vernal from Grand Junction.
