Me_Again
Oct 13, 2020Explorer III
wnjj wrote:Cummins12V98 wrote:
My truck sets level as it should. I get flashed on occasion.
You pretty much should never get flashed. Maybe consider slightly lowering your headlight aim, particularly as your truck ages and may settle a bit lower.
Ron, has the rear air ride suspension. It is always at the same height, will not settle with age, unless the system fails. He does use the alt height setting and maybe should adjust for that.
I run my fog lights all the time as they fill in the area above the cut off line a little. On the RAMs you push the button and it remembers on restarts. Wished they would have done that for the exhaust brake also.
