In our 26lrss I bought a dbl towel rack, attached it to a piece of oak plywood that I edge finished, stained and sprayed with clear lacquer, then attached the whole thing to the wall with molly bolts. I had to cut the bars on the rack shorter to make it fit better. Also you will need a piece of something soft on the end of the towel rack so that when you open the right side medicine cabinet the mirror won't hit the rack and crack. I just used a round felt pad and stuck it on the bar end. There's only one stud on that wall and it's in the middle.
