Photomike's avatar
Photomike
Explorer III
Nov 10, 2013
Heat loss
I do not want to take over the other thread about preheating a camper so I thought that I would start this thread. I was wondering if anyone has ever done any tests to see how long the heat is maintained in your TC.
There are a number of variables (outside temperature, if the inside was completely heated, window types, etc.) but I would like to get some numbers if people have them. I know I need to look into my heat loss when driving and I think I will pick up a infrared thermometer or a thermal camera to do some tests, but was wondering how others compare when moving and when parked.
How fast does the temperature drop after shutting off your heat?
Here is what I have found for my TC:
Parked
Outside Temp 0C (32F) - Inside Temp 20C (68F) - Drop of 1 degree C (1.8F) in 20 minutes*
Outside Temp -20C (-4F)- Inside Temp 20C (68F) - Drop of 1 degree C (1.8F) in 8 minutes
Moving
Outside Temp 0C (32F) - Inside Temp 20C (68F) - Dropped to 10C (50F) in 30 minutes
Outside Temp -20C (-4F) - Inside Temp 18C (64.4F) - Dropped to -5C (23F) in 30 minutes
* At 0C (32F) outside when parked the temp stabilized at a loss of 3 degrees C - 5.4F (17C - 62.6) after 45 minutes and one person and one dog in camper
Thanks,
** Edited to show F
  • Can you please run back outside and then test the moving temperature drops to see what happens when the furnace is left running. I've read many accounts of people that have driven with their furnaces running, and think I have done it too, only because I forgot to shut it off, but it's extremely rare for us to be driving at 0C for any length of time, and unheard of to test it at -20C.
    Can a running furnace keep up? Is it safe to allow it to just run without cycling off and on?
