DcoleramExplorerSep 23, 2013Heat strips in the ac unitsDoes any one have them? How do you like them? Also they only run off shore power or a gen set correct? Dave
AlternExplorerSep 23, 2013They put out approx the same heat as a space heater although usually not as localized.Its all about volt x amps = watts.Watts can be converted to show btu's.Read all about it HERE
Related ContentAdding Heat StripsAddning heat strips to heat pump AC unitsChanging heat pump to heat stripHeat stripDometic Heat Strip DMR702
