sleepy
Sep 23, 2013Explorer
Dcoleram wrote:
Does any one have them? How do you like them? Also they only run off shore power or a gen set correct?
Dave
The 50 Watt a/c heat strips are absolutely useless.
A single 1500W ceramic heates run on the low setting will be enough 90% of the time.
I'd like to remind you: but I know that everyone already knows this.
All 1500 Watt heaters will put out the same amount of heat ( BTU's )
The maximum size heater that can be plugged into your 110 Volt AC power source is 1500 Watts.
I see room heaters advertized as being something very special from the Amish... at $300 or more. Look carefully... they are 1500W
I see them for $60... yep... still 1500 watts
A very nice 1500 watt thermostatically controlled ceramic heater with three speed fan and an off switch can be had for less than $30.... at Walmart... or shop around.
No matter what you pay... 1500 Watts is as big as it gets... you can get less for your money.
44,071 PostsLatest Activity: Aug 16, 2026
