sleepy
Sep 24, 2013Explorer
The question that comes to mind as I read....
Can you get it for $20
It will still be only 1500 watts maximum if it plugs into a 120 VAC outlet. The wiring wouldn't take it... you blow fuses and breakers with higher wattages.
The $20 ceramic cube is the smallest fan powered device available to get the 1500 watts... the outside is kept realitively cool as the 3 speed fan pushes the heat out into the room.
And 8 months a year in most areas of the country it's easily stored away... and quicly brought out if needed
I have a $300 vented Platcat, others have a $200 Wave... I'll bet most of us would still use our $20 Ceramic Cube 1500 watt heaters when we have 120VAC available.
44,071 PostsLatest Activity: Aug 16, 2026
