bobndot
Oct 22, 2013Explorer III
stickyeye wrote:
Better off just filling on board tank for water use and drain when done and re-winterize the unit. If you don't have a winterize valve that bypasses the on-board water tank and can draw directly from the rv antifreeze bottle you should install one. Only take about 1-1.5 gallons of antifreeze to winterize my unit.
Sticky
x2
do like we do in the fall. Fill the fresh water tank and use the tc pump, repeat if/when u need to. No hose to freeze .
44,056 PostsLatest Activity: May 04, 2014
