RavensFan24 wrote:
Mine works the same way. My wish is that the thermostat would show the ACTUAL temperature in addition to the set temperature. When the heat runs, I feel like it gets super hot (well over how it was set) and then it cools off to what seems like well below how it was set. It makes me wonder on occasion if the propane is low or out, though I've noticed with the heat running more now that I'm in MD that the system won't kick on at all (fan and furnace or even just fan) if there is no propane.
Yes,, thats my issue, If I could reduce the amount of fan run on after the flame goes out it would retain the heat. Instead it feel like it is blowing off the heat generated.
