Boatycall
Nov 07, 2014Explorer
My first guess - your battery is not grounded well. That would one of the few reasons your 12v converter can light it but a brand new battery won't. It's grounded enough to spool the fan, but the voltage drop is enough to not allow the igniter to fire.
As a quick troubleshooting test - Try running a regular car-type jumper cable from the ground of the battery to the metal casing of the furnace and see what happens. Basically, run a good ground to the furnace.
Also see if the fan speeds up when you do this.
44,056 PostsLatest Activity: May 04, 2014
