tlukasavige172
Nov 09, 2014Explorer
Here's an important learning lesson. When you buy a used camper that someone else has worked on make sure the battery is connected correctly. The problem was the fan was running backwards and the cables on the battery were switched. After testing the cables with a voltmeter I was able to confirm they were wrong (thanks to the advice found here). I can't believe it didn't fry a fuse but they are all still intact. Trying to make sure the fridge works but I have found there is a fuse missing for it (found that while tracing his problem).
44,056 PostsLatest Activity: May 04, 2014
