DaButcherExplorerNov 19, 2013Heater questionsHow much do I need to take apart to clean? Is it normal to have a brick next to the heater? The brick was there when I pulled the heater. Show More
n7bsnExplorerNov 19, 2013No the brick is not normal. I would consider replacing, that's what I did with an old one of a similar type. I installed an Olympic CAT heater (8100ET, no longer made)
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsHot water heater question .....Replace insulation inside heater column.Water Heater Leak on start up.
