DaButcherExplorerNov 19, 2013Heater questionsHow much do I need to take apart to clean? Is it normal to have a brick next to the heater? The brick was there when I pulled the heater. Show More
Alfred622ExplorerNov 19, 2013Unless someone added a brick to capture the heat and radiate it more slowly??? But on the inside of a cabinet?
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsHot water heater question .....Replace insulation inside heater column.Water Heater Leak on start up.
