DaButcherExplorerNov 19, 2013Heater questionsHow much do I need to take apart to clean? Is it normal to have a brick next to the heater? The brick was there when I pulled the heater. Show More
robsouthExplorer IINov 19, 2013Maybe someone started to build a fireplace and decided that it would not fit?
Related ContentAtwood water heater problemWater Heater Replacement RecommendationsHot water heater question .....Replace insulation inside heater column.Water Heater Leak on start up.
