wanderingbob wrote:
Assume that the only issue was to get heat into the truck cab as soon as possible ! Would you start truck and get up to up to hiway RPMs and speed quick or would you maybe travel slower in a lower gear .
Highway speed RPM sounds good except that puts colder air across radiator and motor .
What do ya think ?
Highway speeds while turbo is producing some boost will produce more heat quicker. The key is for the turbo to be producing boost.
Having said that my truck has the electric heating element that produces heat for the cab until the engine coolant can produce enough heat. Great feature...
