Range Maggot Bob wrote:
ktmrfs- Okay, I'm going to get my manual out and try it. Never remember reading about that in my manual, but if you say it's so, I will find out. As far as the high idle set with cruise control, I have to disagree. In high idle with exhaust brake on, my truck, as I said before, is warm and toasty in 5 minutes. Thanks for the info!
the info on setting the automatic "warm up" is in the diesel supplement. On my 04.5 w/o the DIC the procedure involved turning ignition on, hitting either gas or brakes x times in y seconds then turning the ignition off. Once set it would come on whenever I started the truck under cold enough conditions with parking brake set etc. etc.
On my 15 Denali with the DIC it is set in the setup screen and you either turn it on or off. again, once set it will come on automatically.
