JiminDenver
May 18, 2015Explorer II
With a new battery, how did you charge it up before you took it up to the trailer? Also did you bring it back down with you for charging? The reason I ask is there isn't enough sun this week for your little panel to bring the battery back up. Letting it sit partially discharged will kill it off quickly.
One thought is without using the fridge and hot water heater you have a lot of line filled with air to purge.
44,059 PostsLatest Activity: Mar 18, 2026
