thcguy12's avatar
thcguy12
Heater won't work - am I missing something? HELP
So our first overnight trip in the TT was a success last night. But we had one issue - I turned on the heater and all it blew was cold air for hours. Never got warm.
The battery was on (fan worked fine) and the gas was on (cooking on stove). I called the person I bought it from and they said all you do is hit the ON button on thermostat and turn heat up to ___ degrees (whatever you want it at). It is supposed to light the pilot automatically.
I read the instructions and they are kinda complicated/confusing - wonder if anyone here can tell me what I am doing wrong?
1.) SET THERMOSTAT TO LOWEST SETTING
2.) TURN OFF ALL ELECTRIC POWER TO APPLIANCE (what does this mean - unhook battery for a second)
3.) TURN SHUTOFF VALVE TO OFF (is this the off switch on thermostat or the nob on propane tank outside or what)?
4.) WAIT 5 MINUTES
5.) TURN ON ELECTRIC POWER TO APPLIANCE (what does this mean - hook battery cables back up or what?)
6.) OPERATE HEATER FOR 5 MINUTES WITH JUST FAN AND GAS OFF
7.) TURN SHUTOFF VALVE TO ON (do they mean outside on propane tank)?
8.) TURN SWITCH ON BOTTOM OF THERMOSTAT TO ON POSITION
9.) SET TEMPRATURE NOB TO TEMP DESIRED
  • It would be nice to know brand/model of furnace....info is always good start
    Last 2 steps are key (all the other steps are for initial/first time/after repair steps)
    SET TEMPERATURE KNOB TO TEMP DESIRED
  • You probably had some air in the line. Try turning the furnace off, running the stove for a couple min, and then turning the furnace back on. It may take a few cycles to work out any air and get ignition.
    It is possible that the DSI for the furnace is bad, or that the thermocouple is bad. Do you hear any attempts at ignition or ignition?
    Stand by the exhaust outside when it starts and see if it gets hot and then cold. Hot will be HOT so do not burn yourself.
  • The box where fan is under cabinet is just that a box - can't see inside or any place with screws to remove face. Not sure where the pilot is.
  • Wow Bruce that was a little harsh. I guess some people were not taught manners!
    OP. All that is there for is to make sure you do not have a trailer full of gas and then try to lite the furnace. Turn it off for 5 minutes then try to turn it back on. Do you have access to the furnace to see if it is trying to lite?
