swimmer_spe's avatar
swimmer_spe
Heating the trailer in the winter
I have a grocery list of things to do inside my TT. As winter sets in, I am thinking of tackling each item over the winter.
Is there any dangers of turning the furnace on to heat it up so I can be warm while I work?
Some of the work will involve the electrical and propane systems. When I do that, the heat will be off and the energy source deactivated.
  • I like to put the trailer in the driveway and plug it in to work on it. Then there is power, lights, and juice for the heater or A/C. Tools are close by. Open the vent a crack a window.
  • do it quite often when doing repairs in the winter, likewise using AC in the summer. As long as the trailer isn't in an enclosed space your ok. And don't have the trailer such that the furnace exhaust would vent into or very near your house either.
    Don't want any CO issues.
  • As long as the trailer isn't in an enclosed storage space so you have proper ventilation, running the furnace should not be a problem. That's what the furnace is for, warming up the interior for when you are in there.
  • The only real issue is when you do electrical then perhaps no 12v for furnace and when you do LP then no gas for the furnace. I suggest a nice heavy duty extension cord to the rig powering a ceramic heater when furnace cant be used. They can warm a rig fairly well and in this case keeping your tanks warm is not an issue.
  • No different then heating it up when using trailer.
    If you have working 12V DC and propane..run the furnace
    Course if battery is only source for the 12V DC then will need recharged long before running out of propane
    Rule of thumb (sorta)....1 battery/1 night of furnace
