TxTiger's avatar
TxTiger
Height above bed rails
I'm picking up my new to me truck camper tomorrow and have a question about how to gain height above the bed rails. My bed interior height is 20", and I believe the "up" height of the TC is 20.5", maybe 21". I've been advised that you want the TC about 1.25 to 1.50" above the rails. I know I could set a piece of appropriate thickness plywood in the bed to get the correct height, but wonder if plywood has too slippery of a surface that might allow the TC to slide a bit. I can do something more permanent when I get home if necessary, but does anyone use plywood?
Any advice or information is greatly appreciated.
  • Cold country people will set the camper on foam insulation panels
  • I added a 2x2 frame to the bottom of my TC. No movement, storage.
  • plywood with rubber mat on top of it. in my 2006 Dodge I had 5th wheel rails so I had 2 pieces of 1/2" plus a piece of 1/4" all screwed together. others here have said they use that foam insulation sheets. I had not hard that until after I put in the plywood, I might have tried that.
